Camber Bushes Fitting
Have a word with a company called SUPERTYRES in Maldon. It's only about half an hour down the A130, then Through Danbury, and you're there. It's next door to the fire station, just off the Morrison's roundabout where they're building a massive new Vaux/ Saab dealership. They do wheels, tyres, and 4-wheel laser alignment, so give them a call, and they should be able to fit them and set it all up properly for you. I always use them for tyres, the owner's a really nice guy.
Hope this helps!!!!
Hope this helps!!!!
red16V
when you lower the rear of the calibra and cavaliers with irs the camber is to much. basicly the top of the tyre tilts inwards. instead of being 1 degree from vertical as it should be it goes up to 4 degrees (depending on how much you have lowered) this means you are running on the inner edge of the tyre and not the whole width. good for racing if set up properly but not for road use.
callyben
<!--QuoteBegin-red16V+--><div class='quotetop'>(red16V)</div><div class='quotemain'><!--QuoteEBegin-->Have a word with a company called SUPERTYRES in Maldon. It's only about half an hour down the A130, then Through Danbury, and you're there. It's next door to the fire station, just off the Morrison's roundabout where they're building a massive new Vaux/ Saab dealership. They do wheels, tyres, and 4-wheel laser alignment, so give them a call, and they should be able to fit them and set it all up properly for you. I always use them for tyres, the owner's a really nice guy.
Hope this helps!!!!<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks very much,but rang em and.........NOPE!!!
Fostersice17
What about that new VXR performance place
<a href="http://www.vxrperformance.co.uk/perf_centre/index.html" target="_blank">http://www.vxrperformance.co.uk/perf_centre/index.html</a>
I guess it wont be cheap but it's not strictly a vauxhall place with it being a joint venture with triple8
I believe it's based in luton so not to far.
Will
Will
WillsToy
