FWD LET with F28 Virtually no understeer
by LE16 » Wed Nov 08, 2006 5:01 pm
Anyone else find this?
I have got virtually no understeer on my FWD LET SE5. Probably coz it has so much power it pulls me out of understeer before it happens.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
by Rusty_CallyT » Wed Nov 08, 2006 5:02 pm
your obviously not trying to turn fast enough [img]/tongue.gif[/img] i get understeer in my 4x4 turbo if i push it a bit much.
Rusty_CallyT
by nikp » Wed Nov 08, 2006 5:57 pm
Yup, not trying hard enough. And you shouldn't have to really try either! It's quite easy to understeer the cally.
2004 Black Evo 8 with blacked out lights. Lookin' mean!
HKS Camshafts and turbo hotside fitted. HKS downpipe and 3" cat by-pass. RR'd @ 401bhp. Target reached!
by T.F.S. » Wed Nov 08, 2006 6:42 pm
<!--QuoteBegin-se5+--><div class='quotetop'>(se5)</div><div class='quotemain'><!--QuoteEBegin-->Anyone else find this?
I have got virtually no understeer on my FWD LET SE5. Probably coz it has so much power it pulls me out of understeer before it happens.<!--QuoteEnd--></div><!--QuoteEEnd-->
utter garbage my friend, utter, utter, garbage
T.F.S.
by Chavtastic » Fri Nov 10, 2006 8:06 am
<!--QuoteBegin-se5+--><div class='quotetop'>(se5)</div><div class='quotemain'><!--QuoteEBegin-->I have got virtually no understeer on my FWD LET SE5. Probably coz it has so much power it pulls me out of understeer before it happens.<!--QuoteEnd--></div><!--QuoteEEnd-->
If you get oversteer, try using the handbrake to spin yourself straight [img]/smile.gif[/img]
by LE16 » Fri Nov 10, 2006 10:22 am
Understeer isnt caused by power, thats wheelspin. It aint garbage and i drive it hard. Have had both the 4x4 and fwd and I have virtually no understeer - simple as.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
by nikp » Fri Nov 10, 2006 10:25 am
Understeer is not caused by power! or wheelspin It's caused by a loss of traction in the front wheels. This loss of traction can be caused by many factors. Ice, water, tyres, weight of front end (One of the reasons the calibra suffers so easily from it - it has a LOT of weight up front), design, torque applied, momentum, etc, etc.
If you aint got any understeer in a front wheel drive turbo calibra, then you're obviously driving it like a granny.
by Stupink » Fri Nov 10, 2006 11:03 am
I would suggest possibly the engine isn't making peak power perhaps? you didn't have a boost gauge did you? have you fitted one yet?
by T.F.S. » Fri Nov 10, 2006 11:09 am
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->I would suggest possibly the engine isn't making peak power perhaps? you didn't have a boost gauge did you? have you fitted one yet?<!--QuoteEnd--></div><!--QuoteEEnd-->
power or no power provided it can do 20mph before a tight corner it will understeer..., a 1.0 nova understeers just like any other FWD car
this guy is either on a windup or he does not know what understeer is
T.F.S.
by Stupink » Fri Nov 10, 2006 11:13 am
Agreed, however hence he's on about it because its a let and "has so much power it pulls it out", i presume he's booting it.. you can't boot a fwd let around a corner even *under* 20mph lol. not unless you're at daytona perhaps? lol.
by nikp » Fri Nov 10, 2006 11:14 am
<!--QuoteBegin-T.F.S.+--><div class='quotetop'>(T.F.S.)</div><div class='quotemain'><!--QuoteEBegin-->this guy is either on a windup or he does not know what understeer is<!--QuoteEnd--></div><!--QuoteEEnd-->
Never a truer word spoken! You can sneeze and get a calibra to understeer!
by T.F.S. » Fri Nov 10, 2006 11:20 am
yea, the only way you can "pull it out" is if you have backed off the throttle mid corner and got it wrong, back comes out, lift off oversteer.....apply throttle to pull car out
T.F.S.
by T.F.S. » Fri Nov 10, 2006 1:26 pm
<!--QuoteBegin-Chavtastic+--><div class='quotetop'>(Chavtastic)</div><div class='quotemain'><!--QuoteEBegin-->Exactly, I was taking the p**s [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
some of us did realise that mate..
T.F.S.
by cally2003 » Fri Nov 10, 2006 3:13 pm
I never use to really see any understeer on my ecotec.
On the turbo, I can drift her :-)
cally2003
by Rusty_CallyT » Fri Nov 10, 2006 4:26 pm
how the hell do you drift it?
Rusty_CallyT
