adjustable rear bushs????????
Chaps i gotta fit some of these rear adjustable trailing arm bush's on my cally t. The only thing is i have no instructions with this kit. I can see how you get them out and in but how do you adjust them?? I've got a bush that is in 2 halfs with an insert and a 4" bolt which has some splines around the collour and then i have 2 bolts for each bush. Sorry but i'm a little confused tbh. Any help would be grand... Cheers
chunkylover
Ok I've fitted these bushs and all sort of went to plan. BUT when i sent the motor of to get the front track sorted out after i lowered it and the rear camber set up, it came back with the steering still out (the other way now) and the camber was apperently correct already, but i only set it by eye!! I find it hard to beleive that i got the camber right on both side setting it by eye but they recon i did.
The thing is now tho that the rear TOE is 55min out on the n/s and 36min out the o/s. I think i'm right in saying that if the rear toe is out the only way to correct it would be to change the rear arms. Does that sound right?
chunkylover
Users browsing this forum: Google [Bot] and 2 guests
