Life span of pads?
Life span of pads?
by sinbrad » Thu Dec 14, 2006 7:01 pm
Hi, guys just wondered what the life span of pads were during ordinary everyday use? Also what are the best pads for all round cost/usage?
by RobbieV » Thu Dec 14, 2006 7:04 pm
<!--QuoteBegin-sinbrad+--><div class='quotetop'>(sinbrad)</div><div class='quotemain'><!--QuoteEBegin-->Hi, guys just wondered what the life span of pads were during ordinary everyday use? Also what are the best pads for all round cost/usage?<!--QuoteEnd--></div><!--QuoteEEnd-->
Can't see there being an answer to that one !
As for which pads cant go wrong with Vaux stuff [img]/smile.gif[/img]
by Shrubie » Thu Dec 14, 2006 10:30 pm
Ive had EBC's before and they were really good but ive also heard good things about Black Diamonds pads. As for the life i dont think you can get an acurate answer on that as everyone drives/brakes different, personally i try and use engine breaking as much as poss so mine will last longer than somone that doesnt!!!
Sorry its a bit vague mate!!!
Shrubie
by sinbrad » Thu Dec 14, 2006 11:40 pm
cheers for that guys. On another note, do replacement pads have to be specific ie pad sensors? I had my pads replaced about 6 months ago and whilst getting my wheels done noticed that the front sensors were not connected, that's if they were actually there? The wires were just tucked away? Are sensors a seperate entity?
by Shrubie » Thu Dec 14, 2006 11:56 pm
Have you got a warning light up on your dash? I only ask cos i have and its because one of the wear indicators has snapped!!! I could be told im wrong but as far as i know it will be persific to your car and you will need ones with sensors.
Shrubie
by sinbrad » Thu Dec 14, 2006 11:58 pm
That's the strange thing, there's no indication at all. So unless the bulb has been remove or there's another explanation then I'm stumped? Will have to check the next time I start the car and see if the check light comes on, if it's supposed to that is?
by Shrubie » Fri Dec 15, 2006 12:15 am
Mine comes on mate so maybe the previous owner got bored of the light and like you said took the bulb out!! Defo worth investigating!!!!
Shrubie
by Rusty_CallyT » Fri Dec 15, 2006 12:17 am
the sensors are about £11 each iirc, single use (if the light comes on the sensors need replacing) so they probably shorted the wires and cut the sensors off
Rusty_CallyT
by sinbrad » Fri Dec 15, 2006 12:28 am
Any idea of part number for the sensors? The wires are bare and just hanging there! (sounded like poetry there) Would it be easy to re-attach the sensors?
by Rusty_CallyT » Fri Dec 15, 2006 12:54 pm
the sensors come with plugs that plug into the look up in the wheel arch
Rusty_CallyT
by sinbrad » Fri Dec 15, 2006 8:17 pm
That's good news. Any idea of the part no.s? Take it a call to VX or autovaux will sort me out?
by Rusty_CallyT » Fri Dec 15, 2006 9:44 pm
phone autovaux they'll sort ye out
Rusty_CallyT
