Do You Reckon These Will Fit?
by imcsherry » Fri Jan 19, 2007 10:25 pm
Thought I'd put a pic of these brakes I managed to get, compared to the Tarox 6 pots:
I'm hoping to get them under 18's with the 310mm discs and then the 6 pots on the rear [img]/smile.gif[/img]
I know the discs are looking a bit rusty but it's off the road for winter.
imcsherry
by Fraz » Fri Jan 19, 2007 10:55 pm
My god Ian...I wont even ask how you got them
by Craigieloon » Fri Jan 19, 2007 11:05 pm
how cool would that look. also to have calipers to the same value as half my car sounds good. LOL
Craigieloon
by EY » Sat Jan 20, 2007 12:18 pm
Nice stoppers, they're gonna break your neck [img]/biggrin.gif[/img]
by splinter » Sat Jan 20, 2007 6:12 pm
Very nice ian.
by Phantom » Sun Jan 21, 2007 12:07 am
and I'm hoping you'll be doing the other little mod of installing a small putty knife in the dash which comes out to peel you of your windscreen, my god will look forward to seeing those on
Phantom
by andy1 » Sun Jan 21, 2007 3:05 am
i can see it now, in the news today man found stuck to window screen
andy1
by STEVA » Sun Jan 21, 2007 1:06 pm
Fook me ian ill have to pop over for look at those monsters, You havent had the six pots on that long so how much did you pay for them then
Bet the other half doesnt know how much you paid for them cos she will be the one whos doin the breaking lol
by DeepSnoozer » Sun Jan 21, 2007 4:13 pm
cool
DeepSnoozer
by imcsherry » Sun Jan 21, 2007 6:05 pm
<!--QuoteBegin-STEVA+--><div class='quotetop'>(STEVA)</div><div class='quotemain'><!--QuoteEBegin-->Fook me ian ill have to pop over for look at those monsters, You havent had the six pots on that long so how much did you pay for them then
Steva<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi Steve
Yeah pop round, just give me a ring, Monday is good for me (tomorrow).
You probably won't guess how much they were but you are right about the misses!
Ian.
imcsherry
by eagle » Fri Feb 02, 2007 8:48 am
please don't take this the wrong way ... but ..
are you sure they will fit onto the disc corectly??
think its time to gt som bigger discs for them calipers .. the swept area of the disc will be miles too small .... also the breaking pressure will be possibly be reduced as the clamping area on the disc will be too large ..
on the correct size disc you will find that the pressure will be much greater as the clamping area will be smaller ..
but fook me them are hoooge ...
eagle
by imcsherry » Fri Feb 02, 2007 9:35 pm
Looks like they are going to be too wide across the calliper i.e. would dig into the wheel itself (and the wheels are as wide as I can go) but over the disc area it looks like they would be OK. I'll take a better look when I've got the other jobs done on the long list I have to do.
imcsherry
by chunkylover » Sun Apr 01, 2007 6:46 pm
Sorry to hijack an thread but i 've got myself a massive set of calipers off a merc S class. They are a pair of Brembo 4 pot calipers but i have the same problem as the will dig into the wheels.
The question i wanted answering was that if i was to get say a 15mm spacer for each of the hubs would this cause a problem in the way of the TXB havin extra camber on each of the wheels???
chunkylover
by dicky » Sun Apr 01, 2007 9:27 pm
Be sure to use drilled discs to eliminate brake fade as these calipers will have allot of stopping power if offerd up to the correct master cylinder.
Braided hoses all round?
dicky
by chunkylover » Mon Apr 02, 2007 6:38 pm
If porsche and lambos still use drilled discs its good enough for me.
chunkylover
Users browsing this forum: Bing [Bot] and 4 guests
