Calibra Camber Adjustment
ive been looking at the kmac kit myself, its expensive though.
as for the ball joint idea, do u recon D bolts would to the job to bring the ball joint in more?
<!--QuoteBegin-bodgetastic+--><div class='quotetop'>(bodgetastic)</div><div class='quotemain'><!--QuoteEBegin-->I bought the set that they 'did' for the front and returned it as it was very poor quality. Looks like they must of stopped selling it for that reason.
That looks the sort of thing you want !
The way I got around it was to cut the ball joints of the lower suspension arm and pull them in slightly. Sorted the problem out and was a dam sight cheaper!<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheater2k
