Central locking problem
by dannova12 » Thu Mar 08, 2007 1:38 am
Ive got a problem with my central locking, it was working fine and now i get nothing. The fuse is fine and ive tried another drivers side solenoid and motor from another cally which i know works and got nothing. I also changed the central locking module (in the footwell under the ecu) for one which i know work as tested in another calibra, and still get nothing. Is there a realy or something that im missing?
Please help as the fuel flap lock had locked in place which meant i had to mess around at the petrol station to remove it just so i could put petrol in the car.
dannova12
by the_one » Sat Mar 10, 2007 9:02 pm
is it working from the passenger side?
the_one
by Rusty_CallyT » Sat Mar 10, 2007 9:26 pm
checked all the microswitches?
Rusty_CallyT
by Phantom » Sun Mar 11, 2007 11:00 am
I take it you're locking the car with the key from the drivers door, inspect the back of the lock as there's a ring which operates the micro switch which brakes off, if it has it will be lying in the bottom of the door
Phantom
by the_one » Sun Mar 11, 2007 1:48 pm
phantom any idea how much that ring is? mine's broken, i still have normal central locking just the dead lock that doesn't work.
the_one
by Leigh » Sun Mar 11, 2007 3:49 pm
Should only be a few quid (less than a tenner I think)for that ring. Mine partially broke a few years ago (before I fitted a remote locking kit), can't remember the vaux name for it, but the guy in stores ID'd it from their parts diagrams over the phone without much problem.
Leigh
by the_one » Sun Mar 11, 2007 5:50 pm
thx leigh, easy to fit?
the_one
by Phantom » Sun Mar 11, 2007 8:25 pm
it's a little bit fiddly as you'll need to take the door handle out, then strip the lock down, there's also a very small ball bearing so make sure you do it on a table inside so you don't lose it
Phantom
by the_one » Mon Mar 12, 2007 4:52 pm
cheers phantom, i'll give it a go [img]/smile.gif[/img]
the_one
by dannova12 » Fri Mar 16, 2007 3:52 am
ive investigated all of the above and still no light at the end of the tunnel. Even when i sit in the car now with all doors locked and operate the locks inside nothing happens. Although when i lock the car from outside i can hear the boot deadlock, but none of the door servos make any noise.
dannova12
