sprin removal
sprin removal
by rob » Mon Mar 26, 2007 6:10 pm
I have a set of front struts in the shed and I need to get the springs off (25mm lower ones) can I just undo them or will they fly off, will I need a compressor.
rob
by Tim2001 » Mon Mar 26, 2007 6:56 pm
should really have a spring compressor or failing that some other way of stoping them from going ping [img]/smile.gif[/img]
Tim2001
by Rusty_CallyT » Mon Mar 26, 2007 7:36 pm
use a spring compressor unless you want to loose an eye
Rusty_CallyT
by rob » Mon Mar 26, 2007 8:48 pm
thanks
rob
by Phantom » Mon Mar 26, 2007 9:22 pm
they're pretty easy to get hold of most places will hire them out for the weekend
Phantom
by marko » Thu Mar 29, 2007 9:10 pm
did mine with 2 bits of rope and a couple of spanners, worked for me
marko
by icewizard » Thu Mar 29, 2007 9:12 pm
<!--QuoteBegin-marko+--><div class='quotetop'>(marko)</div><div class='quotemain'><!--QuoteEBegin-->did mine with 2 bits of rope and a couple of spanners, worked for me<!--QuoteEnd--></div><!--QuoteEEnd-->
Rope??? You're a braver man than me.:eek:
icewizard
by marko » Thu Mar 29, 2007 9:49 pm
its not the safest way admitted but im a bit of a nutter when it comes to cars, do as the others say, get some spring compressors.
marko
Users browsing this forum: Bing [Bot] and 11 guests
