Which rear bushes should I change??
by icewizard » Mon Mar 26, 2007 10:16 pm
Just wondering what would be the most important one's to change, does anyone have any experience here on what makes a differencs.
On this page items 2, 6, 13 and 10???
<a href="http://sugardonut.co.uk/cpg/albums/userpics/10001/EPC_Image_Print.pdf" target="_blank">http://sugardonut.co.uk/cpg/albums/userpic...Image_Print.pdf</a>
And on this page 2,8 and 11???
<a href="http://sugardonut.co.uk/cpg/albums/userpics/10001/EPC_Image_Print2.pdf" target="_blank">http://sugardonut.co.uk/cpg/albums/userpic...mage_Print2.pdf</a>
I was looking at powerflex bushes, has anyone used the ecentric bushes to correct camber, are they worth it and any good??
icewizard
by davefly76 » Mon Mar 26, 2007 10:23 pm
on the first pic i would only bother with 2 and 6. number 2 being the ones to correct camber.
on the second pic go with 2 and 8. number 2 are quite common to fail anyway.
[img]/smile.gif[/img]
davefly76
by icewizard » Mon Mar 26, 2007 10:35 pm
Thanks mate, them will be the ones then.
Powerflex do a version of Item 2 on the first page with an offset bolt entry so you can rotate the bush to correct camber. Has anyone on here had any of these. There about £16 each.
icewizard
