Nearside rear brake knocking
by debairaclijr » Wed Apr 18, 2007 11:42 am
Hi all, seem to have developed a knocking coming from the back lefthand wheel when I apply the brake. It cant be heard at high speed but is clearly audiable under 30mph.
Local mechanic says it sounds like the handbrake (which IS due for a new cable) but, considering the sound occurs whist operating the foot brake, i'm not convinced.
Recently had new pads all round and new handbrake drum.
Any advise appreciated.
Thanks
debairaclijr
by Robs-se » Wed Apr 18, 2007 12:38 pm
I had a ticking coming from my rear brakes and also a squeaking in reverse.
Have a look at the brake shoes a retaining pin might have come out where the back plate rusts.
Rob
by debairaclijr » Wed Apr 18, 2007 1:55 pm
Cheers dude, i'll make sure it gets checked. Any other suggestions?
debairaclijr
For anyone interested...
by debairaclijr » Sun Apr 29, 2007 12:23 pm
....it was due to the brake pad springy spacer thing rusting away to nothing. now the pad hits the caliper when I brake. Anyone know what this part is, how I can get hold of one and how to fit?
Cheers all
debairaclijr
by tommycon45 » Sun Apr 29, 2007 12:34 pm
<!--QuoteBegin-debairaclijr+--><div class='quotetop'>(debairaclijr)</div><div class='quotemain'><!--QuoteEBegin-->....it was due to the brake pad springy spacer thing rusting away to nothing. now the pad hits the caliper when I brake. Anyone know what this part is, how I can get hold of one and how to fit?
Cheers all<!--QuoteEnd--></div><!--QuoteEEnd-->
one of mine did that, was down to the retaining pegs and springs, cheap from any motorspare shop, easy to do as well
tommycon45
by Phantom » Mon Apr 30, 2007 12:25 am
you can get new guide pins and retaining springs from vauxhall as well, the sound you're hearing is the brake pad hitting the disk as the spring is not holding the pads back, it's either rusted that badly it's not doing its job or its no longer there
on another note, what pads were fitted, genuine GM ones?? as someones fitted the cheap ones on the rear of my turbo and they actually rattle when you go over bumps
Phantom
by debairaclijr » Thu May 03, 2007 5:44 pm
Nail on the head Phantom, Cannot work out what that god damn rattle is or where its coming from! It sounds aweful. I thought it was the exhaust out of alignment and was just about to roll it into quickfit earlier.
so how do I go about stopping this? I'm due for new discs soon anyhow so shall I just do the lot in one? Baring in mind i'm a cheap ar%e and will probably go for the cheapest I can find.
Nice one. + your way
debairaclijr
by Phantom » Sat May 05, 2007 1:47 pm
yes I'd wait until they need doing
if you're a member of the club you'll have access to the trade club account at vauxhall, genuine rear brake pads are £10.03 and new rear disks are £49.95 I'll bet you'll pay the same at any of the other suppliers or local motor factors for non genuine parts, choice is yours really, the £20 membership is soon got back once you start buying parts
Phantom
Users browsing this forum: Google [Bot] and 2 guests
