drilled and grooved brake discs
by RobbieV » Sun May 20, 2007 11:06 pm
The grooves won't make it grip any better they just help to deglaze the pad better and the holes help to disperse the gases and heat generated by the pads and discs.
by stainesy » Sun May 20, 2007 11:13 pm
oh right ok. spose it dont matter witch way they go then.
stainesy
by RobbieV » Sun May 20, 2007 11:21 pm
Put them on which ever way please's you [img]/smile.gif[/img]
by Robs-se » Mon May 21, 2007 2:09 am
does it matter. i thought they would just be plug and play ie just put them on
Rob
by marko » Mon May 21, 2007 6:55 am
marks are right, thats what i was told when i brought mine, groove meets outside edge of the pad first
marko
by stainesy » Mon May 21, 2007 8:08 am
thought so
stainesy
by Phantom » Mon May 21, 2007 12:18 pm
I've had Mintex pads before and although they stop well I got loads more brake dust than normal and they ruined a set of disks in a year
Phantom
by stainesy » Mon May 21, 2007 3:07 pm
great iv already bought them now
stainesy
by andy1 » Tue May 22, 2007 1:44 am
if the discs are going the way marks do, they are bound to collect a lot of brake dust and crap of the road as they are traviling grove forward, where if they are traviling grove facing away from road they will throw the dust out of the grove, just my logic
andy1
by Phantom » Tue May 22, 2007 2:08 pm
I'm not trying to put you off from buying them but be aware you might be changing pads and disks again a lot sooner than you thought
Phantom
by stainesy » Tue May 22, 2007 2:23 pm
well iv already bought them now so i may as well use them. not that bothered bout the dust. nothing a good wheel clean cant sort out.
stainesy
by Fostersice17 » Wed May 23, 2007 5:38 pm
Iv'e always stuck with EBC pads,never had any problems with them.
Fostersice17
by Phil » Thu May 24, 2007 5:15 pm
I opted for the standard Vaux pads and uprated the discs to drilled and grooved. Once bedded in, they are awsome!!!
Makes the oddest noise when braking though as the pad runs over the grooves lol.
Phil
