Oil Pressure sender wire
Have acquired the VDO gauges for the SE2 but would like to know where the best place is to send the wire through the bulk head to connect it up.
Rob
Rob
Will be putting in the gauges soon, but what is the best way to join the wires
into say the DID for the live wire, light dimmer etc. Do i cut the wire and then
rewire into one of those plastic block things or can i slip the wire into the already
existing connection on the DID?
Rob
Rob
