Airbag warning light
Ever since I bought the car this light has always remained on when I drive the car. The passenger airbag cover on the dash looks a bit warped, as in it looks like someone tried to prise it off or something, so I'm guessing the previous owner was messing about with it for some reason.
Does the car have to go to Vauxhall to investigate, or can any garage do it? I know I can remove the bulb behind the clocks, but I'd rather have working airbags in my car...
Sam
Sam wrote:OK, cheers.
Randomly I found that mine got reset without going to the dealership using TFS's ECU reboot system... i.e. take -ve battery connector off, hold brake pedal down then switch ignition on and off again.. Then leave for an hour.. I've no idea if it actually reset it but the lights gone out.... :banana:
r3mi
