C25xe tuning chip in a X25XE
As far as i know there are 3 ECU's used in the V6 from 1994 to 1998 and ive never seen a chip for the X25XE ECU, seen plenty of re-map chips for earlier V6's but not for the last ones.
As for getting around the immobiliser set up i don't think you can, hence it causing problems if you fit it.
