interior light..back windscreen wash...
since i bought my p-reg calibra eco tec the interior light has never worked-checked fuses and there fine and replaced bulbs as well but still doesnt work...any ideas??
plus-back windscreen screen wash doesnt work...any things i could try to get this fixed??
any help would be great...thanks....robert
whamburto
does the interior light come on when you pull on the head light switch,
and for the rear wash it could be blocked pipe or blocked jet, try changing the pump, if that dont help then replace the tube, bit of a pain to do as it is under the roof lining, or do what most people do forget about the rear wash,
andy1
Re: interior light..back windscreen wash...
whamburto wrote:plus-back windscreen screen wash doesnt work...any things i could try to get this fixed??
You may find that the water pipe has come off the arial base, which is behind the head lining. It's a right pain to fix as you have to drop the back half of the lining.
