URGENT!! sunroof won't close and it's starting to rain
by M005tng » Tue Nov 20, 2007 11:11 am
Hoping somebody can help me....I opened my sunroof this morning to let out the filthy smell my friend had just created and now it won't close again.I only opened it upwards didn't slide it back but now if I try to close it I get nothing but if I try to open it some more I just get a loud clunking noise.Is there anyway I could close it manually for the time being? Appreciate any info anybody can give.cheers. Neil
M005tng
by wozza » Tue Nov 20, 2007 11:38 am
In the centre of the roof is a plastic circle just behind the sunroof itself remove that and you will be able to use an allen key in there to manually close your roof.
think ive explained this correctly if not im sure someone else will add something :)
cheers
warren
wozza
by bodgetastic » Tue Nov 20, 2007 1:29 pm
wozza wrote:In the centre of the roof is a plastic circle just behind the sunroof itself remove that and you will be able to use an allen key in there to manually close your roof.
cheers
warren
Makes sense to me :wink:
by wozza » Tue Nov 20, 2007 2:10 pm
cheers bodge :)
wozza
by Stupink » Tue Nov 20, 2007 2:31 pm
if all fails don't worry too much. the sunroof is very well designed, it can cope with the vast majority of rain types/angles so long as its only tilted not moved back. unless the rain is torrential golf ball sized drops and/or being blown horizontal by a hurricane it will probably stay all but dry inside.
by Tim2001 » Tue Nov 20, 2007 2:42 pm
instead of opening the sunroof open the door and kick the smelly git out. Then this problem would not arrise.
Tim2001
by Phantom » Tue Nov 20, 2007 2:46 pm
lol @ Tim
Phantom
by Calibra_Mike » Tue Nov 20, 2007 4:51 pm
As said above the sunroof can be open and closed using an allen key... you should see a round blanking cap near the interior light...
by M005tng » Tue Nov 20, 2007 11:43 pm
cheers for the help lads.I'll have a go in the morning.I've wrapped a towel in plastic and stuffed it in the gap so it should be ok for the night.
M005tng
by M005tng » Wed Nov 21, 2007 1:14 pm
tried closing it with the allen key but it just kept unscrewing and out comes a screw with a little cog on.lol.I tried using the the buttons whilst I could see the motor and it turned slightly so the motors not dead.So I pulled the rubber seal from around the sunroof opening and had a peek over the roof lining and it turns out the passenger side runner isn't moving at all when I press the button.But if I try moving the actual sunroof itself with my hands the passenger side moves so it looks like the runner has disconnected somehow.I was thinking of unscrewing the hinge but it looks like its all rivets or something.will I have to take off all the roof lining and if so how do I go about acheiving that.
M005tng
by scotte84 » Thu Dec 13, 2007 9:28 pm
Hi it seems i have the same problem, any advice would be great.
scotte84
by RobbieV » Thu Dec 13, 2007 9:39 pm
How to remove the headlining from Wilkybar-kid (Richard)
http://www.clubcalibra.net/viewtopic.ph ... highlight=
by smarty100 » Thu Dec 27, 2007 9:34 pm
hi there my sun roof jammed the other day and i got somebody to operate the switch inside while i pushed it from outside toward the front of the car and it shut , i was pretty worried 4 a while but it worked as it wasn't quite forward enough to close.
smarty100
by MR Gee » Thu Dec 27, 2007 9:49 pm
when I bought my Calibra it came with an allen key for this very purpose, the key was shaped like a cranked handle.
MR Gee
by Mark1 » Thu Dec 27, 2007 11:18 pm
I just don't worry about...............................I've not got one.
Club Treasurer
Club Treasurer
Users browsing this forum: Bing [Bot] and 14 guests
