Possible Alternator problem?
First of all Happy New Year to you all.
Went out to car the other day after not using it for day and a half or so and the Battery was dead, and i mean Dead (RIP)
jump started it all ok, volt meter showing 14+volts. stopped it, started again no problem. So alternator seams to be charging ok. My question is why did it go flat in the first place? A freind has told me that if an alternator fails in a certain way it can actually drain power from the battery when not running, any truth in this?
Thanks Andy
Thanks Andy
Sounds more like the battery has gome than the alternator, just because it shows that it's charging doesn't mean that it's ok. I'd start by getting it checked.
Andy if you've only had it 3 months then take it back and get them to check it, it must still be under warrenty.
Get the battery checked out by someone like ATS etc... they'll also be able to tell you if the battery is charging ok, which should mean the alternator is working fine. Sounds like something might have drained the battery though, do you have an alarm, maybe that would have something to do with the problem, go through a checklist in your head and try and narrow down the possibilities...
Easier to say than do... I know ive been there lol
