GM Battery
GM Battery
Got one of those Vauxhall GM go batteries and it went flat on me so gave it a charge overnight now for the problem.
Battery charger says battery fully charge but the indicator on the battery is still black (Flat) instead of Green (full) ?
Is my battery knackered and time for a new one ?
Mine does the same but appears to work fine... although if im messing about with the car and ive got it on the drive with the doors open (interior light on) then after an hr or two I do have problems with starting the car... Think its still working ok just not got much time left...
If I remember right, they dont charge very well after the black dot has come up and thats telling you it's time to change it.
Most good motor shops should have a good line in Batteries. It's the time of year for them to fail.
pas wrote:They are so called "dry" batteries and they are not rechargeable - it think its even dangerous to recharge (might explode or something like that) - once its flat that is it you need a new one...
There not "dry" and they are rechargeable.
Time for a new battery
try these robbie, any time i've had to replace a battery i've always replaced it with one of these. you pay a bit more but they are a good battery mate
http://www.barden-uk.com/varta-automoti ... eries.html
splinter wrote:Hi Robbie.. I dont think you can charge them.. i had the same thing on mine mate.. If you want to take it back let me know i have two friends who work down there![]()
Aslong as its daveys.. lol
This battery i think is over 3 years old (Smurf's old V6) if you can swap it for new via your mates then ................................... Yes please
