remote locking
remote locking
by sib » Sat Jan 26, 2008 7:37 pm
can anyone help?wired up following the vague instructions.the door locks then unlocks repeatedly.thanks in advance to any solutions
sib
by tommycon45 » Sat Jan 26, 2008 10:12 pm
hiya.
i fitted a vauxhall remote locking kit,,, the fitting was pretty straight forward,,,sure i`ve still the diagram somewhere,,, i had a problem with the door locking then unlocking,,, it was down to the passenger dock locking mechanism sticking ,, i know of others that locked while going over bumps,,, traced it down to the wiring connectors
tommycon45
by MR_TOAD » Sat Jan 26, 2008 11:13 pm
Defo lazy motor in one door
you tell it to lock one motor stays open then it auto unlocks
Drivers door is usually the fault
make sure when you lock with remote the latch moves if not then that is the door
Ian
MR_TOAD
by sib » Mon Jan 28, 2008 3:32 pm
cheers guys, turns out its the boot that's causing the problem.its not unlocking
sib
Users browsing this forum: Bing [Bot] and 7 guests
