ecu light staying on while driving
anybody no why the ecu light is staying on while i drive?? car running like s**t now,slight pause while foot down goin tru the gears,ideling high+failed nct on very very high emishons=[did paper clip test last week and crankshaft sensor came up but car starts most of the time!! driving a 92 4x4 turbo
paudie
just got round to paperclip test again with car running,code 42 and 73 came up...
42 -a- vehicle speed sensor(vss)high voltage
42 -b- 1gear ident switch(c20let systems)high voltage
42 -c- est line coil cylinder 2+3(m2.8/xev system) high voltage
73 - air flow sensor (afs) low voltage
i presume one of these faults is causing ecu light to stay on and why my car is running like s**t!? what parts will i need to get to sort my baby out??
paudie
