Dash Bulbs
these are the ones for the dash little twist and play ones, they also do the volt/oil gauges and clock/temp, if i remember their called a t5 bulb
- Attachments
- 11cb_2.jpg (24.45 KiB) Viewed 18777 times
RobbieV wrote:sinbrad wrote:Back to my original question, what type are the bulbs that are used for the warning indicators on the dash?
Dunno but have a shed load here if you want a few
Cheers but if they're as ally says, t5 then I've got some lying around.
i've got a spare dash here robbie and the only bulb that's differant is the bulb for the battery warning light mate, all the rest are the same. so what's the differance between the t5 and the 509t?
allys cally wrote:i've got a spare dash here robbie and the only bulb that's differant is the bulb for the battery warning light mate, all the rest are the same. so what's the differance between the t5 and the 509t?
Ah see your point and just had a look at a spare dash
As for the difference i don't know as ive never heard of a t5 all i know are 509T bulbs as found on here -
http://www.ultraleds.co.uk/automotive-b ... 963150fa51
so their the same thing, i was told they were a t5 maybe it's me thats wrong mate. but the pic i put up was still the same bulb so at least i got that right
Looks like the dash is coming out this weeked, just want to make sure I've got the right replacements. It's my battery warning light that's gone and if that's the only one that's different I want to make sure I've got a spare? I take it that although the indication is RED, the actual bulb has a white output?
the battery warning light is a bigger bulb than the rest mate, ive got a spare one here if you pm me your address i'll send you it up.
on its way to you
