Help pse?Brake Lights flash with Indicators.
by andym1fjg » Thu Feb 21, 2008 10:22 pm
Help Pse, my 93 calibra kept blowing a fuse when indicating & the fuse on the alarm, so only 1 side will flash, Ive had to put more amp fuses in but this is wrong I know, also now one side is duller then the other when the alrm is activated & while I indicate my brake lights flash with indicators??any Ideas pse tnx.
andym1fjg
by Allys Cally » Thu Feb 21, 2008 10:28 pm
check the bulb holders in the rear lights they might be corroded
by cally8valver » Thu Feb 21, 2008 10:30 pm
yep sounds like corrosion in multi plug to rear lights or bulb holders more common on old fords you know when you brake and they all light up like a christmas tree lol
cally8valver
by BazV6er » Fri Feb 22, 2008 12:16 pm
or a bad earth somewhere .
by Callyman » Fri Feb 22, 2008 1:24 pm
BazV6er wrote:or a bad earth somewhere .
What Baz said, irratic behaviour in a bulb cluster is nearly always a bad earth somewhere. To prove it, have the bulbs flashing and temp' hold a wire onto the earth side of the bulb connection and earth the other end to the body, this should prove if it is indeed an earth problem.
Club Memberships
Club Memberships
