LCD Dash help wanted LOCAL AREA
Hello everyone,
I have an LCD dash which I bought from germany.... I want to know if there is anyone in my local area that could fit it, as I have no experience with electrics what so ever. I live in the Bedforshire Herforshire area and wondering if theres anyone out there.
Also what type of transducer will I need?? I have late spec calibra 4x4 turbo on a 96 plate. Any idea of what type I will need? any part numbers??
PLEAESE SOME ONE HELP ME OUT..
THANKS GUYS.
THANKS GUYS.
k16sst
callyben
right a turbo has an electronic speedo, this is driven by a pulse from the ABS ( IIRC) the pulse duration from the transducer is a different duration. So even if you got one, and managed to fit it ( think the late turbos don't even have a drive in the gearbox for a cable)
it will work...but the speed output Will be way out ..like doing 40 mph will show about 60 mph
Fraz wrote:right a turbo has an electronic speedo, this is driven by a pulse from the ABS ( IIRC) the pulse duration from the transducer is a different duration. So even if you got one, and managed to fit it ( think the late turbos don't even have a drive in the gearbox for a cable)
Already sounds complicated!! So wats the best thing to do!! but other calibra turbos have them fitted they dont seem to have much problems... Help Help
k16sst
well first check and see if you have a drive in your gearbox for a speedo drive
If you have I am wrong..as the speedo transducer pulse will work the LCD dash (sorry bit late head not in gear )
If not then its going to get complicated, as you then need a Prescaler to alter the pulse duration of your existing wire that drives your speedo
or you could just drive with an inaccurate speedo ..and that is perhaps what these other turbos may have done
Fraz wrote:well first check and see if you have a drive in your gearbox for a speedo drive
OK I will check in the morning, but where do I look? obviously somewhere in the gearbox but where? the dash I have in the calibra now doesnt have cable unlike the pre 94 models...
k16sst
k16sst wrote:OK I will check in the morning, but where do I look? obviously somewhere in the gearbox but where? the dash I have in the calibra now doesnt have cable unlike the pre 94 models...
If your dash doesn't have a cable, then the speedo will be pulse driven from the ABS as Fraz has said. Does your original dash have three connectors on it? (one big black in the centre, one blue, and one white)
Here a links to all the guides I used to fit my digital dash... (along with guidance from the mighty sage that is Fraz
Here is a link to the digi dash pinout
Astra digi dash pin assignment
Fitting a digi dash to cav mk3/calibra
Intructions
Fitting a genuine Cav Mk3 Digital Dash (Not your type but has a section on getting the check control working)
More instructions
As for getting the speedo working, Fraz sent me this link...
Speedo pre-scaler
OR you could send a message to migweb member Dom as he makes them
Dom's online shop
I had access to a Tech2 diagnostic unit which displayed the speed signal and I knew that 3k rpm in 6th was approx 80 mph so I had reference points to set up the speedo.
Getting the illumination working was a bit of a problem. As you can see the original clocks in the daylight they don't need any backlighting unlike the LCD panel.
What I did was get a switch which allowed me to switch from an ignition feed (daytime viewing) to the dimmer feed from the headlamp switch for the night.
Rocker switch 081209 On/On
I cut out the panel next to the headlamp adjuster and fitted the switch in there.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
k16sst
