massive boot install, need biger alternator!!!
spec:
JVC Avx33 dvd head unit
sunvisor screens
ps2 with 12v-8.5v ps2 converter
4x pyle chopper components(225watts rms each)
2x kenwood kac ps 621 amps (1200 max)
1x kenwood kac ps 811d amp (1600 max... looking for a second if anyone knows of one!??)
1x 12" audioban immortal sub (2k rms, 4k peak)
2x 1.6 farad power caps
2x4 gauge wired for battery +ive to caps/amps, and 2 gauge from battery to ground, then 4 gauge from ground to caps/amps.
all amps are wired in a loop aswel.
I need a sufficient alternator, its got the 70 amp standard one, which is now fkked I think, its got a heavy duty battery that only just fits in,
its a 2.0 8v btw
any suggestions?
would the 120 amp alternator fit?
also is there anything better than that?
another thing, when u mute or turn volume off there is a hissing noise, how can I get rid of this, it does it when the engine isnt running aswel?
just need some carpet to finish it off!
tempted by the idea of cream leather!:P
Cheers guys and girls
Ross
sunvisor screens
its a 2.0 8v btw
any suggestions?
Ross
PuppiesBalls
Ref Hissing noise, first thing i thought of is do you have power and speaker leads on separate sides of the car?
I was always told to run power one side and speaker/amp leads the other.
Just a thought.
Just a thought.
Right guys, Boot build is nearly finished! my new amps have arrived too( had to get 2 amps as i managed to blow one!:( picked them up cheap though(200 quid each insted of the rrp 400!
new alternators in! fkin tight fit though!! will put some pics of the it up soon!
got my huge braked in too 356mm and 4 pot calipers
yeeehaa:D
yeeehaa:D
PuppiesBalls
Users browsing this forum: Majestic-12 [Bot] and 12 guests
