Battery Wires Help!
the ABS ring is behind the hub, look for a toothed wheel, best way to clean this will be to rotate the hub and clean with a wire brush, the ABS sensor is near to the ring aprrox in the 2 o'clock position looks like a plasic thing with a peg sticking out of it, may need to remove this to clean it or again just clean with wire brush
Phantom
