Aircon Switch
Aircon Switch
by markybrisca » Tue Mar 18, 2008 3:07 pm
Just noticed my SE6 has Aircon but switch does not light up, can a bulb be replaced inside or is it a new switch job. Aircon seems to work as revs drop when button is pressed but it is too cold outside to decide whether fully functional or not. Anyone help me?
markybrisca
by Shince » Tue Mar 18, 2008 3:55 pm
same prob,but im prety sure there is a leak in my system :(
Shince
by RobbieV » Tue Mar 18, 2008 3:59 pm
It probably needs a re-gas.
by trev150 » Tue Mar 18, 2008 4:09 pm
I'm sure the light won't come on if its not working, or put more clearly, the will come on if its working properly.
by RobbieV » Tue Mar 18, 2008 4:09 pm
trev150 wrote:I'm sure the light won't come on if its not working, or put more clearly, the will come on if its working properly.
Correct ;)
by Callyman » Tue Mar 18, 2008 4:10 pm
The Revs dropping just tell you the clutch on the pump is working to run the pump. When the gas become low in pressure to light stops working.
Club Memberships
Club Memberships
by markybrisca » Tue Mar 18, 2008 10:14 pm
Thanks for cheering me up guys!!!!!!
markybrisca
by ross85 » Wed Mar 19, 2008 1:28 pm
If the bulb does need replacing its easier to replace the whole switch. I tried changing the bulb in an aircon switch and ended up snapping the little plastic clips which hold the front on.
ross85
by RobbieV » Wed Mar 19, 2008 3:52 pm
ross85 wrote:If the bulb does need replacing its easier to replace the whole switch. I tried changing the bulb in an aircon switch and ended up snapping the little plastic clips which hold the front on.
Very rare for the bulb to go and easier to replace the whole switch.
by BazV6er » Wed Mar 19, 2008 11:14 pm
i know mine doesnt light up but when you press the switch the engine changes
by RobbieV » Wed Mar 19, 2008 11:20 pm
BazV6er wrote:i know mine doesnt light up but when you press the switch the engine changes
Baz, see Callyman's reply.
