Tyre pressures
Tyre pressures
I was checking my tyre pressures today and 3 of them were at 40psi and the other was low at 25psi.
As I've got aftermarket wheels fitted I can't seem to find anywhere what the correct pressure should be. My wheels and tyres are 215/45/17's, I'm thinking of adjusting them so the fronts are 34psi and rears 30psi.
Ca anyone let me know if this is correct or not
cornishtaz
cornishtaz wrote:That figure is for the original factory fit so it would be the same even though I've got wider but lower profile tyres?
It what i use and most tyre fitters say same pressure as original tyres hence why you can't find any info on tyre pressures for aftermarket wheels.
callyben
Users browsing this forum: No registered users and 50 guests
