boot install
boot install
well i finally decided to make a start on my install. this has been a long time coming ( over a year
so i started with running the live wire from the battery, bit of a pain in the arse that one.
then i connected the wires into the back of my stereo, found running the wires up the side alot easier than when i done my install on my cavalier, due to the fact that the plastic trim is screwed on rather than the clips that you get in the cavalier, therefore no risk of breaking clips this time round
so managed to get all the wires running into the boot, live running up one side of the car and speaker and remote lead running up the other. still got to fix in the earth wire just looking for a suitable place to fix it.
so the next thing for me to do is to start making up a sub box and a stealth shelf for this lot to go in. i've had this lot for a couple of years now and they were a good buy when i got them so i'm just going to stick with them rather than buying new.
INFINITY 9603I 6X9
JBL GTO 1202D 12" SUB
JBL GTO 75.4 AMP
i'll keep you's updated of progress
INFINITY 9603I 6X9
JBL GTO 75.4 AMP
actually get quite a good sound off these, their getting a bit old now compared to some of the sub and amps that JBL do now. but when i got them they were JBL's best on the market at that time.
as for the 6x9's think you can pick these one's up for about £30 now, when i got them they were £140
i did use them they were in my install that was in my old cavalier for 3 years mate
to be honest Trev both sides have wires that carry electrical current, its just because the live is running straight from the battery is the reason they must be kept separate so as not to cause interference.
thats the way i do it as most of a cars wiring for the back of the car runs down the passenger side.
well i've had this wiring kit since i done my install in my cavalier and at the time when i bought it the kit cost me £45. was the dearest one in the place so it must be a good quality one. i also use 1.5mm speaker cables (AUTOLEADS recommended) running from the amp to the sub and 6x9's.
