LET the rebuild begin
Made some good progress over the last week or so. New back bumper now back from the sprayshop and looking good. For those that can remember (or nearly drove into it) I left mine on the A43 on the way back from Billing as it was just too dam low.
Done quite a bit of work on the front bumper to get it to fit but now looks much better and will be going down to get sprayed this weekend.
Brakes now on, no thanks to Autovaux for sending me out three calipers before they got the right ones
Sorted out the brackets for the FMIC so I can move everything back a tad, hopefully the exhaust manifold is going to fit between the rad or its gonna be a lot of moving things around.
And a good flush out of the FMIC ready to go on, nothing too yucky came out though
Finally have some front indicators too, rather than just the lens in position to make it look like I had some
splinter wrote:Nice one will it be ready for combe ???
More like Billing............................................2010
Some more good progress today. First job was the final fit of the rad to check some of the clearences
This is it from the top, im thinking im going to have to mount it quite a bit more forward for everything to fit
Next up I fitted the rear wheels as I wanted to lift the car 'slightly', hoping the handbrake would be up to the job. Engine crane in position, shame the rad had to come out but I didnt want to damage it.
Just high enough for the engine to wheel in
And nicely in....
Belt and engine mount left to fit and I can lift it into position
And nicely in....
two steps forward and step back tonight. First off was to bolt the engine and subframe into position which should of been a big milestone on the project.....
Next was to try the exhaust manifold and I'd forgotten how big it actually is. I was pretty sure it wouldnt fit with the rad in postion but it only just fits without it. Now the catch 22 is I cant fit the manifold with the rad in position and cant fit the rad with the manifold in position. Looks like its gonna be subframe back off, tilt the engine back, mount the rad in as far forward as possible, fit the manifold and swing it into position. Not going to be fun if I have to take any of it out
This is how it looks
Thought I would give the turbo a bit of a trial fit before taking an angle grinder to the front of the car. Was a bit worried about the space between the turbo inlet and PAS pump. Its tight but their is just enough room for a hose after a bit of trimming.
Picked up a new slam panel from vauxhall but am a bit concerned about loosing the rigidity of the front end by having it removeable. Will see how far forward I can mount the rad before cutting it off.
Shouldnt loose any rigidity really if you do it well, reinforce either end where you chop it so the bolts holding it together pull along the full area not just a small bit of the std thickness where it may rip through. Terrible use of english and explanation there, but im guessing you knwo what i mean, its bedtime now so word use limited lol.
Users browsing this forum: No registered users and 88 guests
