oil & amp guage wiring?
hi guys,
i bought some gauges from another calibra only to find i dont have the plug for them, but there is a big black plug there instead..
but now i have a plug that fits and all i need to know is what pin need what? if you look at the back of the gauges at the plug, you will see 4 pins, i can only assume that :
1 is an earth
1 needs 12v
1 needs the signal from the oil pressure sensor...
and i think the last is another 12v for the lights?
here is a pic [img]/tongue.gif[/img]
if anyone can tell me what each is for that would be much appreciated as i have everything sitting here...and they arent hooked up [img]/sad.gif[/img]
(also if anyone has any idea what the black plug is for that would be great too [img]/tongue.gif[/img] )
1 is an earth
1 needs 12v
blueraven
No4 Injector open circuit/incorrect voltage?
the black plug is to change the bulbs
here's a wiring diagram i think it's of the plug as u look at it
Col_UK
leegsi
thanks a bunch guys!
but i have a few problems tho [img]/sad.gif[/img] hooked up the sender wire and when the engine is running my oil gauge is off the meter!!..i have wired all the wires as above.. do you think the sender i have is mor elike just an on/off switch?? i think maybe one of the wires in the graph is mixed up between the lighting wire and the sender, seeing as i get a volt reading, no lighting and a maxed out oil gauge, but no light [img]/tongue.gif[/img] ?
erm.. help!
erm.. help!
blueraven
yeh i found out i need the new type of sensor with 2 wires and not one(that i have [img]/tongue.gif[/img]) so if anyone has a spare or can find one over there for me i would happily throw a few quid their way if they send it to me.
but i still dopnt know why my lights arent working, i ran a wire to my clock light and they dont come on at all. i will try to run it to another light when i get the time [img]/tongue.gif[/img]
thanks again guys
thanks again guys
blueraven
