Jack hammer vibrations: Quick response!
Ok Gang!
I've got the car up on miniramps, but it can't stay long as they're on loan.
I've mentioned on multiple forums a "jackhammer" feeling as I turn into corners. This is on both sides, the NS more than FS.
The ARB links are spot on. No problems, knocked them, shook them, pulled/pushed, no movement or sign of excessive wear.
The wheels are out of balance and the brake disks are warped, however I'm confident this isn't the cause, as this gives a shudder rather than jackhammer.
I've got a whole heap of things I can poke which I've found after crawling under there.. what would you suggest I look for?
I don't know if these will help, but I'll throw them in anyway
Thanks
Jay
Thanks
Jay
DC 12v
DC 12v
DC 12v wrote:1) where do I find them
2) what do they look like
3) would they actually cause that?
when i slam on the brakes for emergency reasons and hit a slight bump the abs looses the plot and sounds fecking awfull.they are behind front discs look like a cog.check for damege i.e missing teeth
on second thoughts no they wouldn't cause that i will shut up
Have replacement front shocks in the Barn. That could be ok to replace.
Diff bearing - where would I find that, and would it affect both sides on cornering?
CV joints, where are they? - You'd be suprised at how mechanically stupid I am - so maybe I missed it?
If any pictures are required, ask. AS I'm literally led under the car typing away lol
DC 12v
Users browsing this forum: Bing [Bot] and 12 guests
](./images/smilies/eusa_wall.gif)
