Ignition amplifier - possible prob?
Cheers Phil. Would it be possible to borrow them as such. At least that way I can see if it's one or the other or both? Obviously postage etc will be covered by me. Car is off the road until at least thursday as new clutch cable being delivered so would be an ideal opportunity to see if the coil etc makes a difference?
Ok, had a look in the area of the battery and just can't see what is supposed to be the amplifier. Can someone please provide some direct guidance, description of the amp and if possible a photo of the amp either in situ or out so i can at least see what I'm looking for?
cheers
cheers
couple of pics here...about half way down, post by Cornishtaz
http://www.clubcalibra.net/viewtopic.ph ... eb8b93489b
Cheers for that Fraz. Went out hunting after I posted my last post and whipped this out as it was the only thing that I could see?? Lo and behold it matches. Now to get hold of another one to see if it's the problem causer?
- Attachments
- P140808_13.20.JPG (209.52 KiB) Viewed 10925 times
Try this guy he's breaking a complete running V6
http://cgi.ebay.co.uk/VAUXHALL-CALIBRA- ... 8794522171
cornishtaz
Been on the phone to local scrappie and they only have vectra v6 so hopefully they'll be the same. Also emailed a couple of sellers on ebay and two got back, one that will sell ecu, coil and amp to me and the other, the one you linked to, has the coil pack and will try and locate the amp. Off to the scrappie in mo so will see what happens?
cheers
cheers
