high oil pressure
high oil pressure
by moosebuster1st » Sun Aug 24, 2008 9:57 pm
Hi, am new to club, just in the process of spending fortunes on a calibra turbo...I am getting high oil pressure (off the gauge) I wondered if anyone with a turbo could say what pressure they normally see whilst under load..
I have covered the basics ie new oil pump (relief valve) new sender about a year ago, new filter etc..
any help would be great,
cheers
Pete
moosebuster1st
by Callyman » Sun Aug 24, 2008 10:02 pm
you should have around 4-5 bar under load, with a idle pressure of 1-2 bar with hot oil
by RobbieV » Sun Aug 24, 2008 10:05 pm
Hi Pete and welcome to the site :)
by moosebuster1st » Sun Aug 24, 2008 10:06 pm
Thanks Andy. mines a 96 too, what oil do you use?
moosebuster1st
by moosebuster1st » Sun Aug 24, 2008 10:07 pm
Thanks Rob
moosebuster1st
by Mark1 » Mon Aug 25, 2008 12:23 am
Hello and welcome.
by Callyman » Mon Aug 25, 2008 12:48 pm
Hi Pete, i'm using vauxhall's own semi 10/40, its pretty good and most guys on here would recommend it
by cornishtaz » Mon Aug 25, 2008 4:01 pm
Hi and welcome, is it going off the scale with the with just the ignition on?
cornishtaz
by moosebuster1st » Mon Aug 25, 2008 7:49 pm
Hi no it is only underload, I found my sandwich plate leaking a bit today so gonna sort that out first, then back to high pressure prob, I guess I better start by using a proper external gauge to measure then go from there..cheers to everyone
moosebuster1st
by moosebuster1st » Tue Oct 07, 2008 10:40 pm
Hi, Just an update to this problem, in case of use to anyone else, I did not suspect the oil pressure switch as it was a new vauxhall item only 10 months ago, however it was the switch at fault, problem solved, so if you get weird high oil pressure (+5bar) it may be the switch (new or not) the gauge moves about above 5 bar under load from just above the 5 bar mark too almost off the gauge, if like me your car has high mileage any weird oil pressure is concerning, at least by replacing the pump, I have no more oil leaks !
moosebuster1st
by Phantom » Tue Oct 07, 2008 10:57 pm
you'll find its the single connection to the switch being loose, crimp it up a little and push it back on
Phantom
by moosebuster1st » Tue Oct 07, 2008 11:05 pm
Hi,
tried that, it did not work, changed the oil switch and now works fine...
moosebuster1st
Re: high oil pressure
by Vxlgsi » Wed May 11, 2011 9:33 am
the oil switch, or the oil pressure sender?
Vxlgsi
by GreyDJ » Wed May 11, 2011 11:43 am
Blimey, you been trawling the old posts? :shock:
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by Callyman » Wed May 11, 2011 5:48 pm
Guys can we check the dates on posts before replying.
Vxlgsi, the thread is about oil pressure so I'd guess he changed the pressure sender.
Users browsing this forum: No registered users and 38 guests
