Electrical problems for my new Calibra
I've just bought a 2.0 8v Calibra of a friend and it has a slight electrical issue, when turning the ignition off the battery light stays on. They were told this was the alternator but i think it's an earth problem. She had bought a new battery for the car about a month ago so it's not a battery issue, i have since been told that the engine management light is coming on aswell so any info would be much appreciated, cheers, Martyn.
Martyn77
Check and clean all of the main earth's including the alternator one. Should that fail then run the paper clip test and see what reading your getting. By this stage you've not spent any money so if you need a new alternator it won't hurt as much. Maybe borrow an alt from a friend and test that?
Markp
