brake light problem
brake light problem
by ferret1985 » Wed Nov 05, 2008 10:45 pm
When the lights are switched off the brake lights work fine. When there switched on you can't even tell your braking, they just stay the same brightness.
Any ideas I could try?
ferret1985
by MJ » Wed Nov 05, 2008 11:34 pm
try putting the proper bulbs in, sounds like you have single filament ones in.
MJ
by Stupink » Thu Nov 06, 2008 12:17 am
Either that or they're in the wrong way and so the sidelights are brighter than the brakelights. Shouldn't be possible to fit wrong way round, but it is if you try hard enough lol! :)
by ferret1985 » Thu Nov 06, 2008 8:23 am
Nah got the right bulbs in I replaced both of them with new ones.
ferret1985
by vinny_69 » Thu Nov 06, 2008 2:37 pm
have you got your rear foggs on :lol:
by ferret1985 » Thu Nov 06, 2008 4:05 pm
Nah there not it's a bit weird
ferret1985
by Phantom » Thu Nov 06, 2008 8:52 pm
only other thing would be a bad earth, try your indicators with all the lights on and press the brake pedal and see if the dim or slow down
Phantom
by Robs-se » Thu Nov 06, 2008 9:33 pm
Bulb holder could be covered in corrosion. they are cheap enough to replace and cured me of a similar problem
by ferret1985 » Fri Nov 07, 2008 12:49 am
problem sorted. gave the holder a good clean and seems to be working fine now. cheers for the help.
ferret1985
