4x4 fault ( think its finally over)
by Richiem » Fri Nov 07, 2008 4:45 pm
Hi all
After changing the pressure switch/ the solonoid / replacing all the fluids/ i finally found the cause of the fault and as always, it turned out to be something odd and simple..
I thought i should check the 4x4 ecu, and when i did i see that the wiring had been cut into and crimped
This was to add the 2/ 4 wheel drive switch onto the steering console..
I also noticed the ecu was hanging loose..
When i moved the ecu, there was a click and the dash light went out
It seems the join in the wiring was naff and the ecu beening loose meant it was probably moving the loose connection whilst driving
I fixed the ecu and took her around the block to test , and the 4x4 stayed on all the way ( so far anyway)
I was just getting ready to give it all up as well
8)
by vinny_69 » Fri Nov 07, 2008 6:24 pm
glad you got to the bottom of it mate,always the simple things go wrong.
by Phantom » Fri Nov 07, 2008 7:51 pm
good news then glad it turned out to be something simple
Phantom
by Stupink » Fri Nov 07, 2008 11:42 pm
doh, well at least you've learnt a lot about the system while investigating all of this. assuming you find it interesting that is lol :)
by cornishtaz » Fri Nov 07, 2008 11:45 pm
good to hear you got it sorted, nothing like people adding connections and making a right arse of it
cornishtaz
by Richiem » Sat Nov 08, 2008 12:22 am
Thinking of it now, it makes sense that this switch could of caused this problem as it switches the 4 wheel drive into 2 wheel drive..
Its been a very good learning experience like you say!
Id never took the accumilator block apart before , and i did it twice..
Users browsing this forum: Bing [Bot] and 18 guests
