abs unit
abs unit
by Callyscot » Mon Nov 03, 2008 8:04 pm
feel that the ABS is not working the way it should be, have removed the fuse and the brakes work fine but with the fuse in when braking even gently judders and noisy. Have a ABS unit from my last calibra (16v) but on checking the part no's 0265 208 011 its not the same as the SE9's( it is similar 0265 208 411 ) or does this not matter. Have checked the fault codes but nothing showing any fault. Any thoughts welcome
Best Presented Billing 2009
Best Interior Billing 2010
Flooded out 2012
Best Interior 2014
by Callyscot » Sun Nov 16, 2008 11:42 pm
thanks for all the thoughtfull comments :!:
Flooded out 2012
Best Interior 2014
by tazz666 » Mon Nov 17, 2008 1:30 am
i think there different mate as the one for the v6 works the traction control and the 16v one doesnt,
as i say i think
by Fraz » Mon Nov 17, 2008 1:46 am
them numbers are the Bosch part numbers, as I said in my pm there are a few listed depending on chassis number..they only list a separate one for a 4x4, non of the others are broken down into engine types
if you can find a GM part number it would help
by RobbieV » Mon Nov 17, 2008 2:07 am
tazz666 wrote:i think there different mate as the one for the v6 works the traction control and the 16v one doesnt,
as i say i think
TC only shares the sensors and feedback from the ABS telltale input is requested by the TC ECU after completion of its' four second initialisation sequence (on ignition switch on).
by v6 steve » Mon Nov 17, 2008 9:05 am
I would have thought that they would be all them same why make diffrent ones for engine size as they would all do the same job?
by RobbieV » Mon Nov 17, 2008 6:58 pm
v6 steve wrote:I would have thought that they would be all them same why make diffrent ones for engine size as they would all do the same job?
V6 info - All V6 Calibras used the combined under bonnet Bosch 2EH system. However, A slightly modified version of the 2EH system was used on late V6's. This version used stronger, more reliable magnetic hydraulic valves inside the main ABS unit (Generation 5).
Not sure if that relates to all Calibra's.
by Callyscot » Mon Nov 17, 2008 7:19 pm
Ok so do you think that the plug on all the V6's is the same so that if I got an ABS unit from a scrapped late V6 that it would fit or does the Abs Ecu come into the it when swapping the original.
Flooded out 2012
Best Interior 2014
by Fraz » Mon Nov 17, 2008 7:25 pm
upto M129999 ...........................................part No 90350609
from N01000001 up to chassis No T1001897 ...part No 90442135
from chassis No T1001898........................... part No 90541364
the one on this cav that is getting stripped is a "P" Chassis so that is part number 90442135
if you let me know what your chassis number are for your old 16V and the SE9 , might be its the same part number listed
by RobbieV » Mon Nov 17, 2008 7:25 pm
Callyscot wrote:Ok so do you think that the plug on all the V6's is the same so that if I got an ABS unit from a scrapped late V6 that it would fit or does the Abs Ecu come into the it when swapping the original.
I would fit an ABS unit from a late V6 cally and see how it goes. you could always take the ECU from the late V6 aswell.
Users browsing this forum: Google [Bot] and 6 guests
