Windows only operating when door switch earths ??
by bobbydazzler » Sat Jan 17, 2009 2:50 pm
:roll: Hi, I need some electrical help. My electric windows are not operating when the doors are shut. However when I open the door thus triggering the earth on the door switch (ie interior light comes on) then the windows work. How can that be ? An earthing problem ?
I would appreciate some expertise I have had everthing apart looking for the problem , but can't work it out :banging:
Many thanks,
Bobby
bobbydazzler
Re: Windows only operating when door switch earths ??
by vinny_69 » Sat Jan 17, 2009 2:56 pm
have you checked the relays?
by Stupink » Sat Jan 17, 2009 3:09 pm
also check the door connector itself, the plugs often get water in them and corrode, give it a good clean and go from there :) no need to strip the door down for that.
by vinny_69 » Sat Jan 17, 2009 3:21 pm
also does it do that with just one door or both?
by bobbydazzler » Sat Jan 17, 2009 4:12 pm
It does it on both windows. You can see the windows bottons on the centre consol light up once the door opens. Then when closed they go off. I disconnected the door connecter and reconnected it. I have looked at the fuses in the fuse box and swapped them.
Also I have noticed my electric wing mirrors are not now working.
bobbydazzler
by vinny_69 » Sat Jan 17, 2009 4:16 pm
so you have changed the relay then,does it work?
by bobbydazzler » Sat Jan 17, 2009 4:25 pm
Just been outside and rechecked fuse box. There was a 2nd window fuse -replaced this - cleaned the door connectors and bingo. All working again. Including mirrors.
Thanks very much for your help, :)
bobbydazzler
by vinny_69 » Sat Jan 17, 2009 4:42 pm
your welcome mate :D
