ECU testing
ECU testing
Has anyone on here used one of these companys that test ecu's? got some problems with my car that i wont go into now but i want to get my ecu tested,can anyone recomend a good company?
Fostersice17
Re: ECU testing
ecu doctor. u send it off, he does all the know how and then he sends it back with a certificate and a test label stuck to the ecu itself
superfox233
Re: ECU testing
test it yourself.
take an ecu out a friends car and try it.. = free
Re: ECU testing
Thanks for the info superfox
Stu i thought your car key matched your ecu? You can't just slap another in can you?
Fostersice17
Re: ECU testing
as far as i know (and i've never had a late ecu, the correct chip needs to be near the ignition barrel, so you can just use your key to start and wave/tape the other key nearby..
Re: ECU testing
i thought the imobileser was in the ecu and the ring around the barrell just reads the key and send the information to the ecu, so the key and ecu need to match. But i could be wroung
Re: ECU testing
I thought the key and ecu had to match,i have a spare ecu from an ecotec,when i get a chance i will put it in and see what happens.
Fostersice17
Re: ECU testing
I think you will need the key for both ECU's though
Re: ECU testing
worth trying and seeing whos right,
Re: ECU testing
later ECU's have the key security code embedded in them. you can change the key chip to match the ecu (if you have the 4 digit code) but you wont be able to do that without the security code and the scanner tool to do it
Re: ECU testing
From what I ca see everyone is saying the same thing, key needs to match ecu, all I've said is you don't need to swap ignition barrel you can just tape the "other" key nearby. If you borrow a mates ecu you will have their key too
Re: ECU testing
Stupink wrote:From what I ca see everyone is saying the same thing, key needs to match ecu, all I've said is you don't need to swap ignition barrel you can just tape the "other" key nearby. If you borrow a mates ecu you will have their key too
that would work i think save changing barrels
Re: ECU testing
Point is i don't have the key to the spare ecu anyway,so is ecu doctor the only company someone has used?
Fostersice17
Re: ECU testing
are you sure your problems are ecu related?
have you tried the paperclip test and read the fault codes?
Phantom
Users browsing this forum: No registered users and 91 guests
