I want to fit some lights under bonet???
by Tattooman » Wed Feb 11, 2004 5:29 pm
Ia n you don't have to purchase the UFO kit, you can buy individual Gems, 1 or 2 ft tubes, they work on their own at a fraction of the cost [img]/biggrin.gif[/img]
Tattooman
by splinter » Wed Feb 11, 2004 9:50 pm
Ok how much and where would i put it????
Thanks.
Insurance
by Murdomac » Wed Feb 11, 2004 10:32 pm
'Its on even if the bonnet is closed' is that like the one in the fridge?
Murdomac
by splinter » Wed Feb 11, 2004 11:21 pm
Yes mate Thats the one.
But i cant get it to work so i will have to get a switc* on it.
by Leigh » Wed Feb 11, 2004 11:29 pm
<!--QuoteBegin-Murdomac+--><div class='quotetop'>(Murdomac)</div><div class='quotemain'><!--QuoteEBegin-->'Its on even if the bonnet is closed' is that like the one in the fridge?<!--QuoteEnd--></div><!--QuoteEEnd-->
Maybe that's why the OE bonnet light was so crap (or so I heard), if it's on even when the bonnet is closed they might have had the first underbody lightting effect with a bright bonnet lamp...
Leigh
by Tattooman » Thu Feb 12, 2004 6:06 am
email phree, he'll fill you in with the details
<a href="mailto:neil@iceled.co.uk">neil@iceled.co.uk</a>
Tattooman
by dazjb » Fri Feb 13, 2004 11:19 am
Fridge lights only come on when you open the door...like your glove box light its controlled by a plunger type switch [img]/tongue.gif[/img]
As a cheap alternative you could wire up 3 sets of 3 LEDS in series on some circuit board and replace the bulb under your bonnet with this. I have done it and now my engine glows blue when I open the bonnet.
dazjb
by splinter » Fri Feb 13, 2004 4:47 pm
I havent got a under bonet light, i have the place to put it, and was going to take the feed from the alarm plunger, but i cant find the live feed !!!
I will have to fit a ****** some where in the car to turn them on and off.
by Phil » Wed Feb 18, 2004 2:09 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Checked the diagram and it seems the power supply comes form the headlight washer relay..which was only on the very early cars<!--QuoteEnd--></div><!--QuoteEEnd-->
Intersting! My under bonnet light doesn't work. Neither does the washers on the headlamps. Where's the relay kept then? I'll have to check it out.
Phil
