lower temp radiator thermostat fan switch
Re: lower temp radiator thermostat fan switch
by vaggelis00 » Sun Jul 19, 2009 10:11 pm
i live in Greece and the summer is really hot. like 35-40 celsius. the prob is that the second scale of the fan starts at 120 degrees. i need to find a fan switch to start lower like 1 scale 95 degrees and second 105
vaggelis00
by vaggelis00 » Mon Jul 20, 2009 9:33 am
i think only gema motorsport had a switch like this but they dont sell it anymore :(
vaggelis00
by Callyman » Mon Jul 20, 2009 10:30 am
How is it running woithout the thermostat in?
If its ok, then the thermostat was shot and not opening fully. get a new STD one.
by vaggelis00 » Mon Jul 20, 2009 11:46 am
its the same with or without the thermostat, both ways the engine temperature is very very high
vaggelis00
by Callyman » Mon Jul 20, 2009 12:30 pm
If it's getting really hot without a thermostat then what good would a cool running stat make?
Sounds like you may have a huge air lock or semi blocked water ways. (if your lucky)
by vaggelis00 » Mon Jul 20, 2009 12:55 pm
i have no prob with the water pump like leaks or some noise. temp was checked through TECH1 and the temp gauge was ok. my headgasket was repaired at EDS in 2004 but i dont know what job was done.
callyman what do you mean by huge air lock?
vaggelis00
by Callyman » Mon Jul 20, 2009 12:57 pm
Means an air lock in the coolant system stopping the water flow,
by vaggelis00 » Mon Jul 20, 2009 1:00 pm
hm...my prob started after installing the fmic and this sounds a little strange about what you say. so i have to open the engine and see what happening inside :(
vaggelis00
by Callyman » Mon Jul 20, 2009 1:07 pm
Do you have a photo of the FMIc on your car? if it's huge and blocking off the radiator then that's maybe your problem
by vaggelis00 » Mon Jul 20, 2009 1:10 pm
my fmic is fitter at the gap of the front bumper and its not huge.
vaggelis00
by vaggelis00 » Mon Jul 20, 2009 2:11 pm
do you need a new photo?
vaggelis00
by vaggelis00 » Thu Jul 30, 2009 12:48 pm
i have replaced the switch rad with one from omega B x25xe. the only one that could make the A/C work and it is lower tha the OE (100-95 from omega).
after a little trip for holidays i realized that when i drive the car and the turbo is over -(minus) 4 bar boost the heat rises. is there a possibility that the water pump cant turn the water fast enough and rise the heat?
vaggelis00
by vaggelis00 » Sun Aug 23, 2009 6:09 pm
finally sorted my prob. it was the radiator. i bought a new one from a 16v cali and everything is ok now
vaggelis00
