digital clock.....
digital clock.....
hi gang just bought a digital clock for the cally...is it easy to convert from the standard clock???
J570_BOO
Re: digital clock.....
Normally unplug old and plug in new.
J570_BOO wrote:hi gang just bought a digital clock for the cally...is it easy to convert from the standard clock???
if you want temp sensor to work youll need sensor and wire up
k1nty
...well its a different connection in the back, so im not able just to plug it in......god dam...lol
J570_BOO
Remove the glovebox and check the wiring loom for another connector, might be wrapped up in foam tape and well hidden.
i bought a white clock for mine a while ago and noticed the plug was different
J570_BOO wrote:...well its a different connection in the back, so im not able just to plug it in......god dam...lol
v6man54deg
