front roll bar size?
ok ive had a good look round and i can only find this but it's for a V6 viewtopic.php?f=18&t=40985&p=419953&hilit=roll+bar+front#p419953
as the cally is slowly getting worse at going round corners i will be replacing the shock's, springs, lower arms and droplinks
but what size are the front roll bar bushes for the 8 valve? im kinda guessing 22mm as my V6 was the same.
Re: front roll bar size?
could be 18mm 20mm 22mm
got the right size for mine by reading the part number off them ...and yes they where still on the car at the time...just had it on ramps a torch and you could just make the number out, camera phone and an enlarged picture got the number and from that I got the right size
Put a mic on that will tell you.
i will have a look tomorrow while im electrocuting myself with me lights
Eh?
Mark1 wrote:Put a mic on that will tell you.
Eh?
if you use a spanner and the one that fits round it its that size ie start with a 17 and then work your way up till one slips over and that will be the size
vinny_69 wrote:i will have a look tomorrow while im electrocuting myself with me lightsMark1 wrote:Put a mic on that will tell you.
Eh?
If you had ask then it's no good telling you.
my guess - 18mm, but anyway - not more then 20mm.
higher number are for "grown ups" - v6, turbo.
IIRC - 24mm and 22mm were for turbos (pre and after 93), 22mm was for v6, those small ones weren't interesting for me.
U_V6
my SE6 has a 22mm one as did the SE2 a C20XE, SE6 a 96 SE2 a 93
though I used the SE2's 22mm one on the se6 as it was originally 20mm
Reason: cause I missed a bit
U_V6 wrote:my guess - 18mm, but anyway - not more then 20mm.
what you will find is all pre 94 calibra's use the 22mm anti roll bar link pendulum and post 94 cars get the newer drop link with the ball joint at the top
guys, for more exact information - just look at EPC. and don't tell me you don't have it. some time ago I looked there and the info was in it.
U_V6
U_V6 wrote:guys, for more exact information - just look at EPC. and don't tell me you don't have it. some time ago I looked there and the info was in it.
i dont have to i am a vauxhall trained partsman , all of the other sizes of pendulum are for the smaller engined cavaliers
Vinny mate buy the 22mm pendulum if it is the rubber pendulum you have on the car,if not you will have the ball joint type ,go have a look
