found a plug!!
Re: found a plug!!
by v6 steve » Sun Apr 11, 2010 12:50 pm
yee it should but it was the only thing i could think of that is that long and comes up the back, i dont know the manifold on the 20L that well but is there a not a sensor down the back ICV or somthing like that is it conected
Re: found a plug!!
by leelee » Sun Apr 11, 2010 3:47 pm
looks like the oil level sensor wire.
Re: found a plug!!
by Calibra_Mike » Tue Apr 13, 2010 6:17 pm
Still trying to find out what the hell this plug does... will be having yet another look tonight...
Re: found a plug!!
by Calibra_Mike » Tue Apr 13, 2010 7:49 pm
the wires are 100% brown and brown/green...
The other end does just join up with the wiring loom... so no idea where it should go...
Re: found a plug!!
by Fraz » Tue Apr 13, 2010 8:49 pm
did you take the wires out that they had between the terminals ???...did any lights come on??
Re: found a plug!!
by Calibra_Mike » Tue Apr 13, 2010 8:50 pm
yep took the wire out... no light came on...
Re: found a plug!!
by henry*r » Wed Apr 14, 2010 10:15 pm
leelee wrote:looks like the oil level sensor wire.
I think leelee is right, exactly the same connector is for your oil level sensor at the top & front of the sump
Re: found a plug!!
by Calibra_Mike » Thu Apr 15, 2010 6:45 am
i agree, found it on the wiring diagram in the haynes and the oil level switch has brown, brown/green wires and would make sense that i get no EML light with it unplugged as its not part of that circuit...
so whereabouts does it plug in?
Re: found a plug!!
by Fraz » Thu Apr 15, 2010 2:19 pm
no not the EML light, but the oil level light should have come on
Users browsing this forum: Google [Bot] and 14 guests
