front quarter window
by daddyt » Mon May 17, 2010 7:59 am
k went out to the car this morning to find some little c**k has scored the small window on the passenger door, its quite deep and also they have shoved something down the rubber so that is now stuck inwards.
so question is , i have a spare door with glass in it ....how easy is it to swap them over...
daddyt
Re: front quarter window
by Phantom » Mon May 17, 2010 11:28 am
tbh it's not the easiest job in the world but can be done if you have the patience for it
Phantom
by daddyt » Mon May 17, 2010 7:46 pm
am gona have to try m8 as it looks awful
daddyt
by Monkey » Sun May 23, 2010 5:55 pm
Just taken the glass out of my doors today, if you have a haynes manual it will help! There is 4 10mm bolts IIRC and a strange screw / bolt at the bottom to adjust it. Once you have this all free and are lifting it out turn it 90 degrees so the adjuster can come through the gap in the door.
Monkey
by big_gordy » Sun May 23, 2010 10:23 pm
its easy if i can do it! take 40 min buddy
