Iceland Blue
Iceland Blue
by Keith1983 » Fri Jun 11, 2010 6:16 pm
Just a quick question for all you experts out there. as it only the 2.0 litre 16Valve SE6's that were produced in iceland blue or are there others?
Keith1983
Re: Iceland Blue
by RobbieV » Fri Jun 11, 2010 6:18 pm
Yes :)
Re: Iceland Blue
by Jamesyboy » Fri Jun 11, 2010 6:19 pm
I thought the se6s were 8 valves and there are lots of combinations with the 16v engines....
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 6:20 pm
So if I wan't an Iceland blue V6 I'll have ot do it myself?
Keith1983
Re: Iceland Blue
by RobbieV » Fri Jun 11, 2010 6:29 pm
SE6 is an 8v 2.0lt engine in Iceland blue only.
Re: Iceland Blue
by Fraz » Fri Jun 11, 2010 6:31 pm
Keith1983 wrote:So if I wan't an Iceland blue V6 I'll have ot do it myself?
The SE6 was the only car I know that came in Icelandic Blue, they are all C20NE engine (the 8V) ....Mine has had the C20XE fitted (the 16V) and if you want a V6 one you will have to change the engine and gear box and the ECU with the loom
You wont get the traction control to work (not with a lot of work changing the car loom) ...its not that hard to do though
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 6:34 pm
can much be done with the 8v engines? I wouldn't be after anything daft but would like 150 bhp ish?
Keith1983
Re: Iceland Blue
by k1nty » Fri Jun 11, 2010 6:40 pm
put a redtop in it.easily done.
k1nty
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 6:49 pm
k1nty wrote:put a redtop in it.easily done.
Am I right in saying they're the C20let engines that they had inthe Cavalier GSI 2000's?
Keith1983
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 9:04 pm
So guess the question is, which is easier respraying a V6 as thats what Id realy like or cpnverting an SE6 to a V6?
Keith1983
Re: Iceland Blue
by v6 steve » Fri Jun 11, 2010 9:08 pm
puting a v6 into a se6 would take a day or 2 a full good respray will take a lot longer and cost 4 times as much
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 9:38 pm
So in idiots terms as I've very little experience with mechanics what would I need for a V6 conversion from a 2.0 litre 8 valve. What on top of an engine, gearbox, and loom?
Keith1983
Re: Iceland Blue
by v6 steve » Fri Jun 11, 2010 9:44 pm
the best way would be to buy a donner car (mot fail) then you will have all the bits there is no fab work to do everthing will just bolt off bolt on
Re: Iceland Blue
by Allys Cally » Fri Jun 11, 2010 9:48 pm
v6 steve wrote:the best way would be to buy a donner car (mot fail) then you will have all the bits there is no fab work to do everthing will just bolt off bolt on
the only fab work Steve would be the stabilizer bar on the driver side strut top, the same as what you did to Jamesyboys ecotec :D
Re: Iceland Blue
by Keith1983 » Fri Jun 11, 2010 9:58 pm
Sounds interesting, I supose if I got a donor car I'd also have plenty of other spares. I presume the brakes were beefier on the V6's? Would it not be worth sticking with the original engine in the SE6 and tuning it a bit?
Keith1983
Users browsing this forum: Majestic-12 [Bot] and 55 guests
