Spectral Makeover
Re: Spectral Makeover
is that all youv done in 9 days come on hurry up
9 days of paying the missus back for buyin the car lol, ive only just done the engine yesterday lol, so now the funds are slowly rolling back in i can get on with it,
right see the panel under the bonnet that the bonnet clips into, and the 2 plates are on, is that changeable?
you mean the part that goes accross the front above the headlights?
lol, it looks bolted on and heated together, my one was a bit roosty, and now bent a wee bit lol
so where is it welded then, coz i cant see,
its welded to the front inner wings and the bottom panel
wont be alot of weld tho fraz? I can see like heat spots on the panel, like tack welds or summit.
Jamesyboy wrote:wont be alot of weld tho fraz? I can see like heat spots on the panel, like tack welds or summit.
spot welds,drill them out.get josh to a dermatologist and tell them about the atf lol.
k1nty
you have to watch the inner wings dont move once you take that out, wont move much but it can be a bugger to get it all aligned correctly again
Urm, you wanna help me when i go to do it then? lmao, that sounds scary and when summit can go wrong, it normally does.
Coz it is rusty, and the forklift that was holdin it up rolled backwards and the handbrake was on on the car and the chain that was holdin it up creased it a bit
