my cally failed mot!!!!!!!!!!!!!!
by john.ness » Sat Jul 17, 2010 1:38 pm
sad day yesterday ma cally failed on brakes,track rod end,lower ball joint,back springs,parking brake no operting properly,front wiper blades not clearing screen,exhaust missins are high!!
so need to start wi getting new disks n pads all round then the rest after argh!!!! think mot tester was having a bad day and took it out on my cally!!!!! :banging:
john.ness
Re: my cally failed mot!!!!!!!!!!!!!!
by bigdaz1987 » Sat Jul 17, 2010 1:52 pm
john.ness wrote:parking brake no operting properly
Its a cally they never work :lol:
bigdaz1987
by john.ness » Sat Jul 17, 2010 1:55 pm
dont get it the shoes have been adjusted so that you can just feel them biting when you turn the back discs and i have fitted new handbrake cable and adjusted and still handbrake is away up high!!! :snooty:
john.ness
by bigdaz1987 » Sat Jul 17, 2010 1:56 pm
mmmm that sounds normal
bigdaz1987
by john.ness » Sat Jul 17, 2010 2:00 pm
but the back wheels lock tight wen on a hill and work fine so why did they fail??? well annoying!!!!
john.ness
by RobbieV » Sat Jul 17, 2010 2:04 pm
john.ness wrote:but the back wheels lock tight wen on a hill and work fine so why did they fail??? well annoying!!!!
Probably too may *clicks* on the handbreak when applied, Have you tried adjusting the cable under the car ?
by john.ness » Sat Jul 17, 2010 2:05 pm
ye its adjusted to the max
john.ness
by tazz666 » Sat Jul 17, 2010 2:22 pm
adjust the handbrake shoes in the drum and then adjust the cable
by Callyman » Sat Jul 17, 2010 3:14 pm
As the guys have said above, loosen the cable and set up the adjusters through the access hole in the drum, one side is easier to do than the other because of the shape of the teeth. If you dont know how to do it, removing the drum will give you an idea of how it works in there. Haynes manual does explain the process.
by john.ness » Sat Jul 17, 2010 3:44 pm
ive done that guys even taken discs off to adjust the shoes,gona check cable aswell
john.ness
by big_gordy » Sat Jul 17, 2010 8:30 pm
would benifit you to be a PAID member and get big discounts!!!! :whistle:
by Jamesyboy » Sat Jul 17, 2010 9:54 pm
put some washers on the adjuster under the car, tried?
by Jamesyboy » Sat Jul 17, 2010 9:56 pm
where it splits from one into 2?
by Jamesyboy » Sat Jul 17, 2010 10:20 pm
john.ness wrote:ye its adjusted to the max
Users browsing this forum: No registered users and 120 guests
