Whurring on turning left
Today i reassembled the front suspension having had it all apart to renew the top mounts and bearings. On reassembley the car now sits better, the passenger side wheel no longer sits near the arch, the top mount plate in the engine bay sits flush with the top of the suspension tower and not on inch above it like before. On driving it now glides over speed bumps and the passenger side no longer scrubs the arch. In fact its now a joy to drive, even the slight wheel wobble has now gone.
The problem i now have is a slight whurring/rubbing noise when turning left, its not as bad as when it first was driven. We have checked all the nuts and bolts are tight, but are now stuck as to what this could be. Anyone any ideas on what it could be.
Oh and thanks for the prezzie Vinny your a star
Re: Whurring on turning left
i would go with the brake sheild as well, i have this happening with my drivers side when i turn left just now too. job for tomorrow me thinks
Ah forgot about that, cheers chaps
Jacked it up and ..... there are no brake sheilds
So took off the calipres and reseated the disks, the one on the passenger side centre was sticking out slightly maybe not allowing the wheel to sit true. Tapped it back in, replaced the calipre and wheel and out for a test drive. PERFECT
. Well happy, no whurring on turning left and no wheel wobble, just waiting for the pads to re bed as braking system is non standard and its now like having a new car. Just need to sort the sump gasket out now
. Well happy, no whurring on turning left and no wheel wobble, just waiting for the pads to re bed as braking system is non standard and its now like having a new car. Just need to sort the sump gasket out nowNothing succeeds like a budgie with nae teeth
Never had one on it when i got it, and never failed an mot which is why i was a bit suprised to not see one there when i took the disc off
Brake shields on the back not on the front, I'm sure Vinnys SE3 when he had the disc off to change his legs also didn't have the shields either and there are picturres on .com also with the same set up of no sheilds on the front either
True, found out from someone that as i have aftermarket brakes its not applicable to mine but if i went back to standard then i would have to get some fitted.
Robs-se wrote:True, found out from someone that as i have aftermarket brakes its not applicable to mine but if i went back to standard then i would have to get some fitted.
that dosnt make sence, im sure Mr C told me if it isnt there how can he fail it
Nope doesn't make sense to me either, in fact i totally agree with you Steve. I have had a mechanic doing wheel bearings on it and he didn't say anything about them not being there and he's an MOT tester. Surely if its a fail he would have told me at the time.
Fraz wrote:
all brake discs must have a rear shield or back plate
Method of Inspection i. presence and security of brake back plates, wheel cylinders and callipers
Reason for rejection i. a brake back plate, wheel cylinder or calliper securing device loose, missing or excessively deteriorated
http://www.motuk.co.uk/manual_350.htm
This must apply to rear brakes as the back plate is the only means of securing the brake shoes. What purpose does the front plate serve? None that i can see in my opinion
This is sorted now as well, been a good day. Driveshaft not tight enough
i know someone elses northcape v6 had the same problem when he bought it,,,,,,
where is the panda hiding anyway
I missed tightening it when i put the strut back on, excited about having a car that didn't crash over speed bumps
