Do you think i could use
Re: Do you thimk i could use
bit of glue some tape ...they will be fine mate
get them all done easy enough then ??
aye mate i did ,all thanks to you and the lads for showing me
i have just been out in it picking up the misses and what a difference , isnt it amazing what you get used to
I've done mine too and it does make a hell of a difference...
F*** me damio you got your money's worth out of them
i was going to get the gaffer tape out aswell,lol
they were original gm ones so they have been on the car along time ,probably since it was new
errrm, what were they, forgive me asking, its 1am and i'm on the first nightshift of the week
looks very much like the were strut tops about 15 years ago
Tangerine
Re: Do you think i could use
as they are on your parts bin i bet when im next up i will find it in it
im sure you can use em again Damo..... door stop paper weight etc
Tangerine wrote:looks very much like the were strut tops about 15 years ago
that would be a neat trick seeing as their the rear bushes
Allys Cally wrote:Tangerine wrote:looks very much like the were strut tops about 15 years ago
ah well, close...at least it was attatched to the car
Tangerine
thats what it would have looked like 15 years ago (the one on the left)
no mate there not , they are very easy, as i was a bit worried before i did mine but while i was up at v6 steves , the lads showed me how it mas done, basically mate you undo the plates 2x15mm bolts and 1x17mm ithink it is , each side but do one side at a time. get a claw hammer and put the claw bit in between the subframe and the lip of the bush, hit with another hammer working around the bush and it will come out, with the new bush i put some washing up liquid on it and it slipped in and then replace the metal braket thing back on and redo the bolts, then repeat on the oppisite side
